Export configuration to another diferent device
I think I already know the answer but if I try to export the whole config from a 433ah to a 750g it will work?
Sent from my Lenovo K50-t5 using Tapatalk
Sure the export will work. But before the import you will have to rewrite the script to be acceptable by totally different device.
I just tried… Worked… somehow
But ETH interfaces were switched… I mean plunged cable in ether1 but in ros the link came up to ether3 I think because the two wireless interfaces from 433 are missing in 750g.
