Tested on ROS 7.7:
having flash full with previous backups, didn’t mention 0% free space,
issued:
/export file=cfg.rsc
result is terminal window disconnected status instead of report smth. like “disk full” error message.
Is this behavior intended ?
Various devices exhibits this behavior, tested on hAP ac (RB962UiGS-5HacT2HnT) and hAP ac^2 (RBD52G-5HacD2HnD).
Old RouterBOARDs are not borned to work with RouterOS 7: have low space if you upgrade the device, because RouterOS 7 is bigger on size and need more memory.
It have (less) low space also if you do not use v7…
What you expect?
