export from V4 to V6 :(
Hello everyone
I have used dude v4 for really many years and finally I bought some RB1100Hx4 and want to upgrade to dude V6.
I’m having some problems :frowning:
I export a backup from version 4 as I normally do backup, and then I will impot it in v6 via: / dude import-db backup-file = dude / backup.2020.01.14.tgz It then reports import failed and I can don’t move forward :frowning:
I then try to extract the tgz file itself with winrar but it says error is it normal?
Is there anything I can do? I just updated the router to 6.46.1
Regards
Jimmy
