Regarding “problems” … I will put the recommended delay in
/delay delay-time=15s
What is still not clear to me is following statement … I have a wAP-AC, so I need to do it ?
It is important to note that for certain devices, the configuration has to be placed inside the flash\ folder.
Warning: If the device has a folder named “flash”, then the confscript.rsc file must be stored in that folder to work with “run-after-reset” command. Everything outside this folder is stored on the RAM drive which contents are deleted on reboot or power cycle.
