Export Network map
I’m using Dude 4.0beta3.
It’s possible to export data of single network map (the goal is import into another Dude server installation)?.
Thankyou!
There is not a way to export a single map but you can copy and paste… If you are using windows when you copy an object it appears on the windows clipboard. You can past that into a different dude… This will also clear the data collected on each object including the copy.
