If I use the last 7.1rc4 with I try export or export file=xy
the command crach.
Do you have any feedback about it?
the command crach.
try
export verbose
It helped in early buggy versions
And probably
export verbose show-sensitive
Also try upgrade to 7.1 Stable
Thanks for the answers.
7.1 didn’t change nothing.
verbose just stop after a while so it works a little more but not fully.
Probably Hap-Lite is not a product to invest more for Mikrotik
Seems many post about this. It looks like its not fixed, and are very slow on Routers with limited CPU. For me it works, just takes loong time on a 400Mhz A radio. Same radio with 600Mhz is better.
