As my thread name already said.
Would I have any problems by fully exporting RB750 and importing all that to RB850?
Would that work normally?
I wouldn’t think so, but you have to try that for yourself, obviously.
I will try that and will let you guys know.
Use export or export compact and you will see.
If there will be any error, it will say you on which lane of configuration file. Or you can turn on verbose mode while importing to see it step by step ![]()
Then you can fix it manually…
