First time posting here. I just upgraded to 6.40rc38 and was trying to export to a file. For some reason it will not generate the file. /export file=backup2017 I then tried just /export and copied / pasted into a text doc, saved it as mikrotik07122017.txt, uploaded it to mikrotik, and tried to run a reset system config with no defaults and no backup. It errors and says invalid file name (6). I then tried removing the extension and it still errors. Lastly, I tried with a know good export file and it error’d again.
Right, I understand that, but for some reason I cannot generate any export files after upgrading to 6.40.rc38. Under /files print, no new files are created. I have tried:
The biggest issue, is that I cannot run the /system reset-configuration from the menu, to reload my exported config (run-after). I get invalid file, I even tried .rsc extension.
Try?
Try??
I think you mean “We will fix this in the next rc version.”.
You do wonder how stuff like this gets broken in the first place, given that none of the relevant code has (apparently) been touched.
Is the whole thing structured so badly that you fix one thing and break another? I really find it very hard to believe.
