Dear Sir’s
Did Any one know how to export MK3 setting to a file, so we
can import it again after format.
Or How to copy Backup file to another location ( like windows drive ).
Also I get am error message when I try backup the MK3 I get
" couldn’t make backup - action failed (6) "
Can any body help me
Eng. Amgad steen
normis
April 20, 2009, 7:27am
2
not backup, backup is to use on the same device.
use “/export file=name” command. make sure to edit this file and remove all unnecessary changes before importing it somewhere. you can edit the file, and even create your own files from scratch - it’s just a list of routeros commands.
Mr. Normis
thanks for your replay, but this file will be saved on the system drive.
I need to take this file to a save location on another pc.
Eng. Amgad
I have FTP server, waht is the code for export to ftp server
Eng. Amgad
normis
April 20, 2009, 8:29am
6
not server! use FTP client to connect to your router, the export file is there to download
I try using Internet explorer, and I found the file anf click on it
I choose to save to my c drive but it give me the login request was denied
Eng. Amgad
normis
April 20, 2009, 9:07am
8
internet explorer is not a good FTP client. use FILEZILLA (it’s free):
http://filezilla-project.org/
Mr Normis
I do not know how to thank you.
You solve a great problem for me.
Thanks again
En. Amgad Steen
