Export SSTP certificates
I’m using CCR1036 7.1.1 device and PPP SSTP VPN solution for external clients. I need to change device and I have a problem with import certs on the new one.
On the old one i have certs with K (KLAT for CA or KIT for Server and client) after import to new router all certs are without K and users can’t connect to VPN.
Help.
Hello
K - private-key
That means you did use a PEM format export without a password.
you can use P12 don’t need to import private keys separately.
