Export to Google Spreadsheet and Google Drive
Hello! I would like to export list of my active hotspot users to Google spreadsheet and Google Drive for every 1-hour with Winbox command but I could do only export to my email. Is there any way to do that?
So I put these in the scheduler and make it execute every 1-hour
/////////////this command is to export list of active user to local file////////////////////
/ip hotspot active print file=active_user_list.txt
/////////////this command is to send that exported file to the email as extachment///////////////////
/tool e-mail send to="xxx@mail.com" subject=“Active User $[/system clock get date] Report”
body="$[/ip hotspot active print count-only] " file=active_user_list.txt
Not directly an answer to your question, but this how I would do it.
Schedule this script (not tested since I do not have hotspot)
:foreach logline in=[/ip hotspot active find] do={
	:local output "$[/ip hotspot active print as-value from=$logline]"
	:set ( "$output"->"script" ) "hotspot"
	:log info message="$output"
Then use Splunk to get the syslog message and create a dashboard to monitor.
See my Splunk for MikroTik here:
http://forum.mikrotik.com/t/tool-using-splunk-to-analyse-mikrotik-logs-3-3-graphing-everything/121810/1
