Searching for ways to do things without “x” never works well.
I want to export items from my MikroTiks but I want to avoid having to put the continued lines back together with my scripts. I can add a subroutine to my scripts to do that for me, but it would be nice if there were an option in RouterOS which would avoid putting them in there in the first place.
If I connect with a terminal, I get lines wrapped as wide as the terminal.
If I “ssh router ‘/export;’ > router.export.txt” I get lines wrapped for an 80 column terminal. I would hope for no wrapping when not in an active terminal.
With “ssh router -t ‘/export;’ > router.export.txt” I get terminal width line (100 columns in this case, not wide enough for the lines I need) but I also get the escape codes which color the output.
That’s not the case: if you’ve connected from Linux over ssh, and you drag the window narrower or wider and re-run /export, the line breaks are in a different place to match the new width.
