hi,
i am running a backup every night using the export command since ROS has no “good” way of doing backup and restore. usually i was able to paste the config into a terminal and it worked. now i am getting errors.
here an example:
[admin@gw-eirewire] > / queue simple
[admin@gw-eirewire] /queue simple> add name=“512-package”
... target-addresses=10.27.54.100/32,10.27.54.101/32,10.27.54.102/32,10.27.1
... 90.103/32,10.27.54.104/32,10.27.54.105/32,10.27.54.106/32,10.27.54.107/
bad argument name 90.103/32 (line 3 column 5)
[admin@gw-eirewire] /queue simple> 32,10.27.54.108/32,10.27.54.109/32,10.27.54.110/32,10.27.54.111/32,10.2
syntax error (line 1 column 7)
[admin@gw-eirewire] /queue simple> 7.54.112/32,10.27.54.113/32,10.27.54.114/32,10.27.54.115/32,10.27.54.1
syntax error (line 1 column 13)
[admin@gw-eirewire] /queue simple> 16/32,10.27.54.117/32,10.27.54.118/32,10.27.54.119/32
[admin@gw-eirewire] /queue simple> dst-address=0.0.0.0/0 interface=wlan1 parent=none direction=both
syntax error (line 1 column 16)
[admin@gw-eirewire] /queue simple> priority=8 queue=default-small/default-small limit-at=0/0
[admin@gw-eirewire] /queue simple> max-limit=128000/512000 total-queue=default-small disabled=no
syntax error (line 1 column 14)
what i actually paste is this:
/ queue simple
just as it comes from the export command.
i noticed this in 3.2 and 3.3, 3.1 and 3.0 i don’t know, 2.9 was fine all along with that way of restoring a config.
regards
Jan
