Extend wifi setup
Hello
A newbie here, with a hap ax2 that works perfectly as a router. From what I have understood, it is not the same process with capsman as before on ax2. I have a mikrotik map 2 that I intended to have to extend my wifi. It can be wired but I’m not sure how to go about it. In the future I want to expand my wifi with more apps but not right now due to cost reasons. Is it possible that I buy more ax products or does it work with all models of Mikrotik’s ap? I have attached my config file if you want you can look at it so I haven’t made a fatal mistake. I have attached my config file if you want you can look at it so I haven’t made a fatal mistake. I think I did the right thing in my beginner setup.
1- config file ?
2- you can not mix legacy wifi (map) with wifiwave2 (ax2) for capsman setup.
You need 1 controller for legacy capsman, one controller for wifiwave2 capsman (if you want to use capsman).
For 1 AX2 and 1 map, capsman is not needed. You can perfectly setup both APs manually.
Here is my config file
conf.rsc (9.02 KB)
See remark 2.
Do you have a good guide that shows how to set one up in the usual way then
https://forum.mikrotik.com/viewtopic.php?t=182373
Para D
