Extend wireless to lan with map lite?
So i have wifi network, AP with dhcp server.
And i would like to connect pc to map lite http://routerboard.com/RBmAPL-2nD over ethernet - lan.
Map lite should work just like antenna, and relay ip addresses from ap.
Now it works but does not relay, only when i have static ip on pc it works, but when i configure on AP
to set 192.168.0.30 on pc MAC it does not assign it, it works when i connect PC to AP with cable, but when i connect it over Map lite where, map wifi to ap and map eth to pc - it does not assign it, How to configure it with winbox or webfig? thanks.
AP= 192.168.0.0/16
has enabled dhcp server and wifi
i want map lite to connect to AP wifi and dont use own dhcp server but make AP DHCP server assign PC connect to mAp lite eth ip address form range 192.168.0.0/16 or static based on MAC on AP conf.
edit:
What i tested now is:
Create security profile, wpa, and it connects to company wifi OK.
Create bridge1 with eth1 and wlan1,
assign dhcp client on bridge1.
So wifi connects to company net, i can go to conf over web,
and pc connects but with some not as i set address, for example i assign on AP for pc mac 192.168.0.30 but it gets 192.168.0.253. I did not set dhcp server on map lite, only on AP.
Is your map in station mode on wireless tab? Then change to station bridge.
it was in pseudo bridge but its ok cause its only one pc behind.
The problem was coincidental - someone in network set his pc ip address on the same i wanted to get, so AP gave me another. Tried different and all works.
