hiiii
i need frequency range 2.7-2.9 Ghz but i disappoint to see this can be done from old mini pci card AR5212 reached 2.732 only
has anybody give me idea atleast how can i get this card for 2.7 Ghz oprations
Thnaks in advance
hiiii
Thnaks in advance
a special permission is required. contact support please
hiiii normis
thanks for reply , i got answer this can be done with AR5212 card and custom frequency … i have already purchased and update arround my all board with custom frequency and planing for huge deployments in spefic ferquency …
can you suggest me for further step or will i wait for corerct mini pci as i know software only read the frequency from chipset EEPROM
correct me if iam worng
after you receive this card, see /interface wireless print. it will display all supported frequencies (read from eeprom). frequency-mode=superchannel will unlock them.
this very common command already done from, last 4 month back
thanks …
so where is the problem then?
problem is that AR5313 based mini pci card not showing the reqiured frequency showing 2.3-6.1 after upgrading the custom frequency ..
i need suggestion for 2.3-2.7 supported frequency
thanks inadvance
most of the cards don’t suport this range, there is no way to have this frequency if the card’s chip doesn’t understand it.
seee the fquency support bu AR5212 mini pci
interface wireless info> print
0 interface-type=Atheros AR5212 tx-power-control=yes ack-timeout-control=yes
alignment-mode=yes virtual-aps=yes noise-floor-control=yes
scan-support=yes burst-support=yes nstreme-support=yes
supported-bands=2ghz-b,5ghz,5ghz-turbo,2ghz-g
2ghz-b-channels=2312,2317,2322,2327,2332,2337,2342,2347,2352,2357,2362,2367,
2372,2412,2417,2422,2427,2432,2437,2442,2447,2452,2457,2462,
2467,2472,2512,2532,2552,2572,2592,2612,2632,2652,2672,2692, 2712,2732
this means that this card will not support 2.9 in any way.
iam ready with this card but iam not sure which card comes with Ar5212…if you have suggestion kinldy suggest
I still don’t understand your problem
if you have this info printout, where did you get it if you don’t have this card?
I don’t think there are ANY cars that support 2900Mhz
I think old CM6 wireless card uses mentioned chipset, the following card does not support 2900 frequencies anyway.
i got the refrenece for 2.7 Ghz from forum …
but there is not mentioend the card manufacrer
simple is that iam looking for 2.7 ghz card atleast if 2.9 ghz is not aviable
iam not facing any problem iam asking for solution for 2.7 Ghz mini pci
which are supported 2.7 Ghz
hi I need “chip info” for those 2.3-2.7ghz (old 5212 cards) do you have it?
like this :
mac:0x4/0x2, phy:0x30, a5:0x17, a2:0x0, eeprom:0x3002
This is really fantastic …pics
hope i will find the chip with the reqiured frequency …
has anybody update me the chipset ..Normis pl take look as this frequency comes with MT …![]()
screenshot was made and in screen shot you can clearly see that application is winbox, so it has to be connected to routeros box, so routeros supports that frwq, you just need to get card that supports that.
i do not see where is the problem? ![]()
and what normis said - that for this moment he does not know if there is any card available. atleast from MT it is not.
thanks for screen shot …can you also update which mini pci card is this …
i never say regarding any problem iam asking mini pci card make which support reqiured frequency ..Definitely MT not make this card…
You’re clearly wrong about this…
Even though winbox reported that very customize frequency, I got list of frequency from 500mhz up to 41ghz, that screenshot is just a little number ![]()
But that frequency didn’t work! Only 2312-2732 works fine.
