I want to connect some computers to an L2 switch (wired) with no wifi and connect the L2 switch over a wireless bridge so that all the computers behind can get their IPs/DHCP from the router that is remote:
This is for indoors, between rooms, and have no line of sight, any advice on a product that could support this? many support the default LAN but not VLANS and in my case I need that the bridge can pass tagged packets
Any of the older wireless mikrotik models, running legacy wireless driver, would do just fine. The newer (ax) devices probably won’t do (for now).
10m indoors might be too much if there are any walls between both wifi devices. Even if it’s cardboard walls, tgey still attenuate radio waves, furniture as well. If there are brick (or even concrete) walls, then … good luck.
There are other options if you can’t pull UTP cable (powerline adapters use electrical wiring, MoCa and G.hn use coaxial cables) which may work better, depending on particular infrastructure layout.
