Extending WiFi Coverage
I have recently purchased a MicroTik hAP ac lite (RB952Ui-5ac2nD). On this device, I have setup 8 SSIDs. Do you know of a compatible MicroTik product that I can use to extend the WiFi coverage area for these 8 SSIDs?
Technically any wireless device MikroTik makes can do this, how many chains the device has being the limiting speed factor.
@rooted thanks for the input. Would you be able to point me to a manual or video in order to achieve this? I’m pretty new to all these.
Thanks!
It depends on how you want to go about it, here is a video that can get you started with one way.
https://youtu.be/-kYJipGK530
@rooted Thank you so much!!!
You’re welcome.
