Extension ETH2 and ETH3
Hello!
I have an RB3011.
1 Wan. 1 Lan.
Lan port is ETH2, how could you make the ETH3 port of Mikrotik also serve for Lan, as if it were an extension of ETH2.
Can’t be easier: create bridge and add both ports to it. Just make sure you update other settings so it uses bridge interface instead of ETH2.
