whatever I do to my single HAP AC Lite, unable to achieve stable Wifi for various home devices- 3 different Android phones, 2 different Windows desktops which time by time loosing Wifi connection. I have in other locations HAP AC, AX3- no issues.
Apartments, few neighbors with APs around.
Changing freq, width, default factory config, tuned config in advanced section- nothing helps. Time by time “extensive data loss” and disconnect.
Previously it was used as just AP in other location without any issues for 4 years. 100Mbps Internet FTTX
Distance to end devices up to 8 meters max; 2 rooms small apartment, router on a shelf near to ceiling, power socket with PS 0.5-1m away. No cables, other radio devices around. Previously in the same place was used HaP AC for many years without problems. Almost the same config.
My observations:
More often when PC start video calls on Teams, Google. Sometimes leads to drops of Wifi for other devices too.
No issues during the night when not used
# may/16/2024 20:53:09 by RouterOS 6.49.15
# software id = P0PD-5G79
# model = RB952Ui-5ac2nD
# serial number = CC3E0CCxxxxx
set [ find default-name=ether1 ] name=ether1-WAN-Telia
add admin-mac=48:8F:5A:62:08:9A auto-mac=no comment=defconf name=bridge protocol-mode=none
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk disable-pmkid=yes group-key-update=6h mode=dynamic-keys name=linkm5-sec-profile supplicant-identity=\
MikroTik wpa2-pre-shared-key=xxxxx
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n country="lithuania" disable-running-check=yes disabled=no disconnect-timeout=3s \
distance=indoors frequency=2417 \
installation=indoor mode=ap-bridge name=wlan2 security-profile=linkm5-sec-profile ssid=xxxx wireless-protocol=802.11 \
wmm-support=enabled wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-n/ac country="lithuania" disabled=no disconnect-timeout=3s mode=ap-bridge name=wlan5 security-profile=linkm5-sec-profile \
ssid=xxxxxx wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
add name=dhcp-pool ranges=192.168.88.10-192.168.88.49
add address-pool=dhcp-pool disabled=no interface=bridge lease-time=1d name="dhcp defconf"
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge comment=defconf interface=wlan5
add comment=defconf interface=ether1-WAN-Telia list=WAN
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf dhcp-options=clientid,clientid disabled=no interface=ether1-WAN-Telia use-peer-ntp=no
add address=192.168.88.0/24 comment="my conf" dns-server=192.168.88.1,9.9.9.9,1.1.1.1 gateway=192.168.88.1 netmask=24 ntp-server=\
216.239.35.0
set allow-remote-requests=yes
/ip dns static
/ip firewall address-list
add address=xxxx list=RemoteMgmSources
add address=xxxxx list=RemoteMgmSources
add action=accept chain=input comment="Remote management" dst-port=38291 in-interface=ether1-WAN-Telia protocol=tcp \
src-address-list=RemoteMgmSources
add action=accept chain=input comment="Remote management" in-interface=ether1-WAN-Telia log=yes protocol=icmp src-address-list=\
RemoteMgmSources
add action=accept chain=input comment="defconf: accept ICMP" in-interface=bridge protocol=icmp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" disabled=yes dst-address=127.0.0.1
add action=accept chain=forward comment="defconf: accept in ipsec policy" disabled=yes ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy" disabled=yes ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new \
in-interface-list=WAN
/ip service
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox address=192.168.0.16/32,78.57.106.249/32,192.168.88.0/24 port=38291
set api-ssl disabled=yes
/ip ssh
set host-key-size=4096 strong-crypto=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1-WAN-Telia type=external
/system clock
set time-zone-name=Europe/Vilnius
/system identity
set name=Router
/system logging
add topics=wireless,debug
/system routerboard settings
set auto-upgrade=yes
/tool graphing interface
add allow-address=xxxx/32 interface=ether1-WAN-Telia
add allow-address=xxxx/32 interface=wlan2
add allow-address=xxxx/32 interface=wlan5
/tool graphing resource
add allow-address=xxxxx/32
/tool mac-server
/tool mac-server mac-winbox
01:24:26 wireless,info 22:AE:BD:EA:20:FA@wlan5: disconnected, extensive data loss, signal strength -67
01:24:26 wireless,debug wlan5: 22:AE:BD:EA:20:FA attempts to associate
01:24:26 wireless,debug wlan5: 22:AE:BD:EA:20:FA not in local ACL, by default accept
01:24:26 wireless,info 22:AE:BD:EA:20:FA@wlan5: connected, signal strength -64
01:31:04 wireless,info 22:AE:BD:EA:20:FA@wlan5: disconnected, extensive data loss, signal strength -64
01:31:04 wireless,debug wlan5: 22:AE:BD:EA:20:FA attempts to associate
01:31:04 wireless,debug wlan5: 22:AE:BD:EA:20:FA not in local ACL, by default accept
01:31:04 wireless,info 22:AE:BD:EA:20:FA@wlan5: connected, signal strength -61
01:31:21 wireless,debug wlan2: 68:5D:43:7F:A1:F2 attempts to associate
01:31:21 wireless,debug wlan2: 68:5D:43:7F:A1:F2 not in local ACL, by default accept
01:31:21 wireless,info 68:5D:43:7F:A1:F2@wlan2: connected, signal strength -66
01:31:23 wireless,info 68:5D:43:7F:A1:F2@wlan2: disconnected, received deauth: unspecified (1), signal strength -66
02:08:39 wireless,debug wlan2: F8:B5:4D:5D:DF:40 attempts to associate
02:08:39 wireless,info F8:B5:4D:5D:DF:40@wlan2: reassociating
02:08:39 wireless,info F8:B5:4D:5D:DF:40@wlan2: disconnected, ok, signal strength -61
02:08:39 wireless,debug wlan2: F8:B5:4D:5D:DF:40 not in local ACL, by default accept
02:08:39 wireless,info F8:B5:4D:5D:DF:40@wlan2: connected, signal strength -61
04:31:25 wireless,debug wlan2: 68:5D:43:7F:A1:F2 attempts to associate
04:31:25 wireless,debug wlan2: 68:5D:43:7F:A1:F2 not in local ACL, by default accept
04:31:25 wireless,info 68:5D:43:7F:A1:F2@wlan2: connected, signal strength -67
04:31:27 wireless,info 68:5D:43:7F:A1:F2@wlan2: disconnected, received deauth: unspecified (1), signal strength -67
07:31:28 wireless,debug wlan2: 68:5D:43:7F:A1:F2 attempts to associate
07:31:28 wireless,debug wlan2: 68:5D:43:7F:A1:F2 not in local ACL, by default accept
07:31:28 wireless,info 68:5D:43:7F:A1:F2@wlan2: connected, signal strength -66
07:31:30 wireless,info 68:5D:43:7F:A1:F2@wlan2: disconnected, received deauth: unspecified (1), signal strength -66
08:09:35 wireless,info 56:32:66:AB:D6:32@wlan2: disconnected, extensive data loss, signal strength -78
08:44:50 wireless,debug wlan5: 66:AD:74:67:03:D0 attempts to associate
08:44:50 wireless,debug wlan5: 66:AD:74:67:03:D0 not in local ACL, by default accept
08:44:50 wireless,info 66:AD:74:67:03:D0@wlan5: connected, signal strength -54
08:44:50 dhcp,info dhcp defconf assigned 192.168.88.43 to 66:AD:74:67:03:D0
08:53:59 wireless,info 66:AD:74:67:03:D0@wlan5: disconnected, received deauth: sending station leaving (3), signal strength -54
08:53:59 wireless,debug wlan2: 56:32:66:AB:D6:32 attempts to associate
08:53:59 wireless,debug wlan2: 56:32:66:AB:D6:32 not in local ACL, by default accept
08:53:59 wireless,info 56:32:66:AB:D6:32@wlan2: connected, signal strength -63
09:07:30 wireless,debug wlan2: D4:E9:8A:5F:F4:56 attempts to associate
09:07:30 wireless,debug wlan2: D4:E9:8A:5F:F4:56 not in local ACL, by default accept
09:07:30 wireless,info D4:E9:8A:5F:F4:56@wlan2: connected, signal strength -69
09:45:05 wireless,debug wlan2: F8:B5:4D:5D:DF:40 attempts to associate
09:45:05 wireless,info F8:B5:4D:5D:DF:40@wlan2: reassociating
09:45:05 wireless,info F8:B5:4D:5D:DF:40@wlan2: disconnected, ok, signal strength -63
09:45:05 wireless,debug wlan2: F8:B5:4D:5D:DF:40 not in local ACL, by default accept
09:45:05 wireless,info F8:B5:4D:5D:DF:40@wlan2: connected, signal strength -67
10:00:32 interface,info ether3 link up (speed 100M, full duplex)
10:10:03 wireless,info F8:B5:4D:5D:DF:40@wlan2: disconnected, received deauth: unspecified (1), signal strength -63
10:31:32 wireless,debug wlan2: 68:5D:43:7F:A1:F2 attempts to associate
10:31:32 wireless,debug wlan2: 68:5D:43:7F:A1:F2 not in local ACL, by default accept
10:31:32 wireless,info 68:5D:43:7F:A1:F2@wlan2: connected, signal strength -69
10:31:34 wireless,info 68:5D:43:7F:A1:F2@wlan2: disconnected, received deauth: unspecified (1), signal strength -69
11:33:48 wireless,info F0:C8:14:05:44:EC@wlan2: disconnected, extensive data loss, signal strength -64
12:07:38 wireless,debug wlan2: A4:D7:3C:22:F1:BA attempts to associate
12:07:38 wireless,debug wlan2: A4:D7:3C:22:F1:BA not in local ACL, by default accept
12:07:38 wireless,info A4:D7:3C:22:F1:BA@wlan2: connected, signal strength -70
12:07:40 dhcp,info dhcp defconf assigned 192.168.88.39 to A4:D7:3C:22:F1:BA
12:07:52 wireless,debug wlan2: A4:D7:3C:22:F1:BA attempts to associate
12:07:52 wireless,info A4:D7:3C:22:F1:BA@wlan2: reassociating
12:07:52 wireless,info A4:D7:3C:22:F1:BA@wlan2: disconnected, ok, signal strength -70
12:07:52 wireless,debug wlan2: A4:D7:3C:22:F1:BA not in local ACL, by default accept
12:07:52 wireless,info A4:D7:3C:22:F1:BA@wlan2: connected, signal strength -66
12:11:31 wireless,info A4:D7:3C:22:F1:BA@wlan2: disconnected, received deauth: sending station leaving (3), signal strength -66
12:33:33 wireless,info 22:AE:BD:EA:20:FA@wlan5: disconnected, extensive data loss, signal strength -62
13:08:29 wireless,info D4:E9:8A:5F:F4:56@wlan2: disconnected, received deauth: unspecified (1), signal strength -69
13:09:15 wireless,debug wlan2: D4:E9:8A:5F:F4:56 attempts to associate
13:09:15 wireless,debug wlan2: D4:E9:8A:5F:F4:56 not in local ACL, by default accept
13:09:15 wireless,info D4:E9:8A:5F:F4:56@wlan2: connected, signal strength -66
13:21:42 wireless,info 38:F9:D3:58:D6:43@wlan5: disconnected, received disassoc: sending station leaving (8), signal strength -69
13:31:36 wireless,debug wlan2: 68:5D:43:7F:A1:F2 attempts to associate
13:31:36 wireless,debug wlan2: 68:5D:43:7F:A1:F2 not in local ACL, by default accept
13:31:36 wireless,info 68:5D:43:7F:A1:F2@wlan2: connected, signal strength -70
13:31:38 wireless,info 68:5D:43:7F:A1:F2@wlan2: disconnected, received deauth: unspecified (1), signal strength -70
14:32:25 wireless,info 16:7B:15:74:67:E6@wlan2: disconnected, extensive data loss, signal strength -75
15:29:56 wireless,debug wlan5: AA:F3:7B:9A:93:CB attempts to associate
15:29:56 wireless,debug wlan5: AA:F3:7B:9A:93:CB not in local ACL, by default accept
15:29:56 wireless,info AA:F3:7B:9A:93:CB@wlan5: connected, signal strength -76
15:29:58 dhcp,info dhcp defconf assigned 192.168.88.34 to AA:F3:7B:9A:93:CB
15:30:00 dhcp,info dhcp defconf deassigned 192.168.88.34 from AA:F3:7B:9A:93:CB
15:30:01 dhcp,info dhcp defconf assigned 192.168.88.34 to AA:F3:7B:9A:93:CB
16:21:32 wireless,info 56:32:66:AB:D6:32@wlan2: disconnected, received deauth: sending station leaving (3), signal strength -62
16:31:40 wireless,debug wlan2: 68:5D:43:7F:A1:F2 attempts to associate
16:31:40 wireless,debug wlan2: 68:5D:43:7F:A1:F2 not in local ACL, by default accept
16:31:40 wireless,info 68:5D:43:7F:A1:F2@wlan2: connected, signal strength -67
16:31:43 wireless,info 68:5D:43:7F:A1:F2@wlan2: disconnected, received deauth: unspecified (1), signal strength -67
17:24:14 wireless,info AA:F3:7B:9A:93:CB@wlan5: disconnected, extensive data loss, signal strength -76
17:24:14 wireless,debug wlan5: AA:F3:7B:9A:93:CB attempts to associate
17:24:14 wireless,debug wlan5: AA:F3:7B:9A:93:CB not in local ACL, by default accept
17:24:14 wireless,info AA:F3:7B:9A:93:CB@wlan5: connected, signal strength -62
17:27:20 wireless,info AA:F3:7B:9A:93:CB@wlan5: disconnected, extensive data loss, signal strength -62
17:27:21 wireless,debug wlan5: AA:F3:7B:9A:93:CB attempts to associate
17:27:21 wireless,debug wlan5: AA:F3:7B:9A:93:CB not in local ACL, by default accept
17:27:21 wireless,info AA:F3:7B:9A:93:CB@wlan5: connected, signal strength -62
17:51:03 wireless,info AA:F3:7B:9A:93:CB@wlan5: disconnected, extensive data loss, signal strength -62
17:51:03 wireless,debug wlan5: AA:F3:7B:9A:93:CB attempts to associate
17:51:03 wireless,debug wlan5: AA:F3:7B:9A:93:CB not in local ACL, by default accept
17:51:03 wireless,info AA:F3:7B:9A:93:CB@wlan5: connected, signal strength -81
18:04:09 wireless,debug wlan5: 22:AE:BD:EA:20:FA attempts to associate
18:04:09 wireless,debug wlan5: 22:AE:BD:EA:20:FA not in local ACL, by default accept
18:04:09 wireless,info 22:AE:BD:EA:20:FA@wlan5: connected, signal strength -52
18:26:53 wireless,debug wlan5: 66:AD:74:67:03:D0 attempts to associate
18:26:53 wireless,debug wlan5: 66:AD:74:67:03:D0 not in local ACL, by default accept
18:26:53 wireless,info 66:AD:74:67:03:D0@wlan5: connected, signal strength -70
18:30:30 wireless,info AA:F3:7B:9A:93:CB@wlan5: disconnected, received disassoc: sending station leaving (8), signal strength -81
18:30:34 wireless,debug wlan5: AA:F3:7B:9A:93:CB attempts to associate
18:30:34 wireless,debug wlan5: AA:F3:7B:9A:93:CB not in local ACL, by default accept
18:30:34 wireless,info AA:F3:7B:9A:93:CB@wlan5: connected, signal strength -55
18:35:47 wireless,debug wlan2: 56:32:66:AB:D6:32 attempts to associate
18:35:47 wireless,debug wlan2: 56:32:66:AB:D6:32 not in local ACL, by default accept
18:35:47 wireless,info 56:32:66:AB:D6:32@wlan2: connected, signal strength -82
18:35:47 wireless,info 66:AD:74:67:03:D0@wlan5: disconnected, extensive data loss, signal strength -70
18:36:11 wireless,info 56:32:66:AB:D6:32@wlan2: disconnected, received deauth: sending station leaving (3), signal strength -82
19:31:44 wireless,debug wlan2: 68:5D:43:7F:A1:F2 attempts to associate
19:31:44 wireless,debug wlan2: 68:5D:43:7F:A1:F2 not in local ACL, by default accept
19:31:44 wireless,info 68:5D:43:7F:A1:F2@wlan2: connected, signal strength -68
19:31:49 wireless,info 68:5D:43:7F:A1:F2@wlan2: disconnected, received deauth: unspecified (1), signal strength -68
19:34:47 wireless,debug wlan5: 38:F9:D3:58:D6:43 attempts to associate
19:34:47 wireless,debug wlan5: 38:F9:D3:58:D6:43 not in local ACL, by default accept
19:34:47 wireless,info 38:F9:D3:58:D6:43@wlan5: connected, signal strength -74
20:53:24 wireless,info 22:AE:BD:EA:20:FA@wlan5: disconnected, extensive data loss, signal strength -58
20:53:24 wireless,debug wlan5: 22:AE:BD:EA:20:FA attempts to associate
20:53:24 wireless,debug wlan5: 22:AE:BD:EA:20:FA not in local ACL, by default accept
20:53:24 wireless,info 22:AE:BD:EA:20:FA@wlan5: connected, signal strength -60
20:56:19 wireless,info D2:CF:4A:AC:ED:E1@wlan2: disconnected, disabling, signal strength -57
20:56:19 wireless,info D4:E9:8A:5F:F4:56@wlan2: disconnected, disabling, signal strength -70
20:56:30 wireless,debug wlan2: D4:E9:8A:5F:F4:56 attempts to associate
20:56:30 wireless,debug wlan2: D4:E9:8A:5F:F4:56 not in local ACL, by default accept
20:56:30 wireless,info D4:E9:8A:5F:F4:56@wlan2: connected, signal strength -67
20:56:31 wireless,info 22:AE:BD:EA:20:FA@wlan5: disconnected, disabling, signal strength -64
20:56:31 wireless,info 38:F9:D3:58:D6:43@wlan5: disconnected, disabling, signal strength -66
20:56:31 wireless,info AA:F3:7B:9A:93:CB@wlan5: disconnected, disabling, signal strength -78
20:56:31 wireless,debug wlan5: 22:AE:BD:EA:20:FA attempts to associate
20:56:31 wireless,debug wlan5: 22:AE:BD:EA:20:FA not in local ACL, by default accept
20:56:31 wireless,info 22:AE:BD:EA:20:FA@wlan5: connected, signal strength -64
20:56:33 wireless,debug wlan5: AA:F3:7B:9A:93:CB attempts to associate
20:56:33 wireless,debug wlan5: AA:F3:7B:9A:93:CB not in local ACL, by default accept
20:56:33 wireless,info AA:F3:7B:9A:93:CB@wlan5: connected, signal strength -74
20:56:35 wireless,debug wlan2: D2:CF:4A:AC:ED:E1 attempts to associate
20:56:35 wireless,debug wlan2: D2:CF:4A:AC:ED:E1 not in local ACL, by default accept
20:56:35 wireless,info D2:CF:4A:AC:ED:E1@wlan2: connected, signal strength -53
20:57:13 wireless,info 22:AE:BD:EA:20:FA@wlan5: disconnected, disabling, signal strength -65
20:57:13 wireless,info AA:F3:7B:9A:93:CB@wlan5: disconnected, disabling, signal strength -73
20:57:14 wireless,debug wlan5: 22:AE:BD:EA:20:FA attempts to associate
20:57:14 wireless,debug wlan5: 22:AE:BD:EA:20:FA not in local ACL, by default accept
20:57:14 wireless,info 22:AE:BD:EA:20:FA@wlan5: connected, signal strength -64
20:57:15 wireless,debug wlan5: AA:F3:7B:9A:93:CB attempts to associate
20:57:15 wireless,debug wlan5: AA:F3:7B:9A:93:CB not in local ACL, by default accept
20:57:15 wireless,info AA:F3:7B:9A:93:CB@wlan5: connected, signal strength -73
20:59:09 wireless,debug wlan5: 38:F9:D3:58:D6:43 attempts to associate
20:59:09 wireless,debug wlan5: 38:F9:D3:58:D6:43 not in local ACL, by default accept
20:59:09 wireless,info 38:F9:D3:58:D6:43@wlan5: connected, signal strength -73
20:59:54 wireless,info AA:F3:7B:9A:93:CB@wlan5: disconnected, extensive data loss, signal strength -73
20:59:54 wireless,debug wlan5: AA:F3:7B:9A:93:CB attempts to associate
20:59:54 wireless,debug wlan5: AA:F3:7B:9A:93:CB not in local ACL, by default accept
20:59:54 wireless,info AA:F3:7B:9A:93:CB@wlan5: connected, signal strength -79
21:01:40 wireless,debug wlan5: 66:AD:74:67:03:D0 attempts to associate
21:01:40 wireless,debug wlan5: 66:AD:74:67:03:D0 not in local ACL, by default accept
21:01:40 wireless,info 66:AD:74:67:03:D0@wlan5: connected, signal strength -45
[Router] /interface wireless registration-table> pr
# INTERFACE RADIO-NAME MAC-ADDRESS AP SIGNAL-STRENGTH TX-RATE UPTIME
0 wlan2 D4:E9:8A:5F:F4:56 no -72dBm@6Mbps 14.4... 18m32s
1 wlan2 D2:CF:4A:AC:ED:E1 no -55dBm@1Mbps 72.2... 18m26s
2 wlan5 22:AE:BD:EA:20:FA no -63dBm@6Mbps 72.2... 17m48s
3 wlan5 38:F9:D3:58:D6:43 no -74dBm@6Mbps 86.6... 15m53s
4 wlan5 AA:F3:7B:9A:93:CB no -90dBm@6Mbps 21.6... 15m8s
5 wlan5 66:AD:74:67:03:D0 no -64dBm@6Mbps 78Mb... 13m22s
@Router] /interface wireless registration-table> pr stat
0 interface=wlan2 mac-address=D4:E9:8A:5F:F4:56 ap=no wds=no bridge=no rx-rate="6Mbps" tx-rate="39Mbps-20MHz/2S" packets=280,222
bytes=14680,12623 frames=87,224 frame-bytes=17185,11529 hw-frames=795,414 hw-frame-bytes=159085,25017 tx-frames-timed-out=0
uptime=20m17s last-activity=750ms signal-strength=-68dBm@6Mbps signal-to-noise=48dB signal-strength-ch0=-71dBm
signal-strength-ch1=-70dBm
strength-at-rates=-70dBm@5.5Mbps 20m17s330ms,-68dBm@6Mbps 750ms,-65dBm@HT20-0 20m15s840ms,-68dBm@HT20-1 20m17s180ms tx-ccq=83%
p-throughput=36145 last-ip=192.168.88.40 802.1x-port-enabled=yes authentication-type=wpa2-psk encryption=aes-ccm
group-encryption=aes-ccm management-protection=no wmm-enabled=yes tx-rate-set="OFDM:6-54 BW:1x SGI:1x HT:0-15"
1 interface=wlan2 mac-address=D2:CF:4A:AC:ED:E1 ap=no wds=no bridge=no rx-rate="65Mbps-20MHz/1S" tx-rate="72.2Mbps-20MHz/1S/SGI"
packets=7287,6271 bytes=4643864,2917050 frames=6018,5891 frame-bytes=4677197,2891027 hw-frames=7339,7653
hw-frame-bytes=6347914,3171889 tx-frames-timed-out=0 uptime=20m11s last-activity=3s790ms signal-strength=-55dBm@1Mbps
signal-to-noise=61dB signal-strength-ch0=-63dBm signal-strength-ch1=-57dBm
strength-at-rates=-55dBm@1Mbps 19s790ms,-56dBm@6Mbps 3s790ms,-58dBm@24Mbps 3s950ms,-59dBm@HT20-0 6m2s790ms,-67dBm@HT20-1 10m2s550ms,-
57dBm@HT20-2 6m3s960ms,-58dBm@HT20-3 6m2s960ms,-58dBm@HT20-4 6m2s950ms,-58dBm@HT20-5 6m2s950ms,-54dBm@HT20-6 10m700ms,-
59dBm@HT20-7 3s930ms
tx-ccq=100% p-throughput=58246 last-ip=192.168.88.36 802.1x-port-enabled=yes authentication-type=wpa2-psk encryption=aes-ccm
group-encryption=aes-ccm management-protection=no wmm-enabled=yes tx-rate-set="OFDM:6-54 BW:1x SGI:1x HT:0-7"
2 interface=wlan5 mac-address=22:AE:BD:EA:20:FA ap=no wds=no bridge=no rx-rate="78Mbps-20MHz/1S" tx-rate="54Mbps" packets=55195,27408
bytes=58099796,6871542 frames=34069,20444 frame-bytes=58650664,6916133 hw-frames=45063,21822 hw-frame-bytes=76617044,7766933
tx-frames-timed-out=0 uptime=19m33s last-activity=2s910ms signal-strength=-62dBm@6Mbps signal-to-noise=46dB signal-strength-ch0=-62dBm
strength-at-rates=-62dBm@6Mbps 2s910ms tx-ccq=104% p-throughput=1312 distance=1 last-ip=192.168.88.30 802.1x-port-enabled=yes
authentication-type=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm management-protection=no wmm-enabled=yes
tx-rate-set="OFDM:6-54 BW:1x SGI:1x HT:0-7 VHTMCS:SS1=0-9"
3 interface=wlan5 mac-address=38:F9:D3:58:D6:43 ap=no wds=no bridge=no rx-rate="86.6Mbps-20MHz/1S/SGI" tx-rate="86.6Mbps-20MHz/1S/SGI"
packets=565245,331530 bytes=687859884,98366700 frames=376416,253692 frame-bytes=691846336,99202753 hw-frames=401956,255430
hw-frame-bytes=765683475,109420499 tx-frames-timed-out=0 uptime=17m38s last-activity=10ms signal-strength=-65dBm@24Mbps
signal-to-noise=43dB signal-strength-ch0=-65dBm strength-at-rates=-69dBm@6Mbps 1m29s810ms,-73dBm@12Mbps 6m1s550ms,-65dBm@24Mbps 200ms
tx-ccq=92% p-throughput=77221 distance=4 last-ip=192.168.88.44 802.1x-port-enabled=yes authentication-type=wpa2-psk encryption=aes-ccm
group-encryption=aes-ccm management-protection=no wmm-enabled=yes tx-rate-set="OFDM:6-54 BW:1x SGI:1x HT:0-7 VHTMCS:SS1=0-9"
4 interface=wlan5 mac-address=AA:F3:7B:9A:93:CB ap=no wds=no bridge=no rx-rate="7.2Mbps-20MHz/1S/SGI" tx-rate="21.6Mbps-20MHz/1S/SGI"
packets=580,470 bytes=394167,86381 frames=451,422 frame-bytes=397903,85286 hw-frames=1188,864 hw-frame-bytes=738605,112742
tx-frames-timed-out=0 uptime=16m53s last-activity=17s500ms signal-strength=-90dBm@6Mbps signal-to-noise=18dB
signal-strength-ch0=-90dBm strength-at-rates=-90dBm@6Mbps 17s500ms tx-ccq=72% p-throughput=508 distance=1 last-ip=192.168.88.34
802.1x-port-enabled=yes authentication-type=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm management-protection=no
5 interface=wlan5 mac-address=66:AD:74:67:03:D0 ap=no wds=no bridge=no rx-rate="78Mbps-20MHz/1S" tx-rate="78Mbps-20MHz/1S"
packets=14987,6001 bytes=17052138,1701977 frames=9155,4760 frame-bytes=17203408,1698731 hw-frames=11683,5341
hw-frame-bytes=23404155,1912478 tx-frames-timed-out=0 uptime=15m7s last-activity=5s880ms signal-strength=-63dBm@6Mbps
signal-to-noise=45dB signal-strength-ch0=-63dBm strength-at-rates=-63dBm@6Mbps 5s880ms tx-ccq=89% p-throughput=70193 distance=1
last-ip=192.168.88.43 802.1x-port-enabled=yes authentication-type=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm
