I get the problems after upgrading from 2.9.
The problem stays with the CB3’s on Prism II mPCI
But a lot worse is that my backbone connections with several of cards 5211, 5212 and 5213 has the same problem, the disconnect random.
My problem is also there are running PPPoE sessions over it and the will all disconnect. With the lastest versions of 2.8 the wouldn´t occur, with versions like 2.8.10 we had the same problems.
We use some rb532´s so we could go back to 2.8
I would prompt MikroTik on this problem, bacause I think it´s a serios problem
we are running all 2.9.7 all signals are <-80 and CCQ´s are >20
one of the backbone links exits with this messages
12:22:35 wireless,info sj: disconnected 00:02:6F:20:FC:B0, no beacons
12:22:35 wireless,debug sj: deactivated WDS link 00:02:6F:20:FC:B0, name wds2.sj.johan
12:22:35 wireless,info sj: data from unknown device 00:02:6F:20:FC:B0, sent deauth
12:22:36 wireless,info sj: data from unknown device 00:02:6F:20:FC:B0, sent deauth
12:22:40 wireless,info sj: data from unknown device 00:02:6F:20:FC:B0, sent deauth (27 events suppressed)
12:22:41 wireless,debug sj: 00:02:6F:20:FC:B0 attempts to connect
12:22:41 wireless,debug sj: AP 00:02:6F:20:FC:B0 not matched by connect-list, by default accept
12:22:41 wireless,debug sj: activated WDS link 00:02:6F:20:FC:B0, name wds2.sj.johan
12:22:41 wireless,info sj: 00:02:6F:20:FC:B0 connected, is AP, wants WDS
I will send also a supout.rif file to support@mikrotik.com
Johan
