External Antenas
I saw some antenna connector on the hap ax2 when i took it apart,
is there a way to connect external antenna there ?
or will it work ? or is it only for like developer purposes where they will “switch” the device to use external and disable the internal ?
thank you
Check if they are the same as the older AC2:
http://forum.mikrotik.com/t/antenna-mod-for-hap-ac2-rbd52g-5hacd2hnd-tc/134432/1
The connectors (in that case) are similar to standard ones, but they are different (and seemingly a bit hard to find).
