External antenna connectors of WAP LTE Kit
Hi!
I bought two units and all works flawlessly as usual, but I don’t see where are the external antenna connectors of the LTE modem.
I think I should open the case (not the screw protected bottom part) and change the internal wires to the internal antennas to my external antennas within a little pigtail and one antenna wire.
The problem it’s I don’t see how to open the case.
We have two holes near the reset button which seems to be there for the external antenna, but I don’t see nothing in manual, brochure, …
You can see in the qucik guide there is info how to open the case:
https://i.mt.lv/routerboard/files/wAP-LTE-wg-171003121743.pdf
“remove both screws below the power jack and slide out the wAP PCB board”
Thanks uldis, I searched on the quickstart guide for external antenna without reading the full document.
I discovered it myself and I was preparing this image :wink:
Thx for the info. Regards,
