External antenna for MikroTik mAP 2nD
The router is placed in a metal box and I cannot mount it outside
Can I connect external antenna for MikroTik mAP 2nD (I want to mount the antenna outside the metal box)?
Photo of the connector
What type of connector is in the picture?
https://en.wikipedia.org/wiki/Hirose_U.FL
This is not a connector, it is a switch MS-156C, used in manufacturing to connect instruments to adjust the device.
https://www.hirose.com/product/series/MS-156C#
There is an adapter for the SMA
https://www.hirose.com/en/product/p/CL0358-0188-8-00
The very idea of putting a homemade antenna system is a very bad idea.
By unsoldering the switch you have disconnected the internal antenna.
Thanks for correcting me ca6ko! Looks like I shouldnt assume something by just looking at it.
However, why would connecting to it an external antenna be such a bad idea?
If you connect the external antenna by a proper connector, the switch disconnects the internal antenna.
As long as you have a proper external antenna, connected well, nothing can go wrong.
The main issue I see here, that the “SMA Conversion Adapter” which you could use to connect to this connector properly,
would probably cost you more than anyone would like to spend on such a setup!
The alternative way, soldering around 5GHz transmission lines by hand would for sure not be a good idea.
Sorry for bringing up an old thread, but wouldn’t such an adapter be okay?
https://pl.aliexpress.com/item/32477442029.html
Yes and no.
Yes It will work.
No that Is not intended for permanent connection, It Is a kind of probe, for temporary connection and It Is too long to be practical.
But this should do:
https://it.aliexpress.com/item/1005007500175358.html
the key is the “mini”.
Thank you.
