External Antenna - Poor Speeds
I have RB751U-2HnD and a Dipol Omnidirectional 6-9dBi MMCX antenna.
I’ve attached the antenna to the router and changed Antenna Mode to: antenna b.
If a check my internet speed at http://beta.speedtest.net/ I get 24Mbps at best. 7 of 10 the speed is less than 10Mbps.
My external line is 300/50Mbps. If I plug cable directly into my computer speed will to to 270Mbps, so I know everything is ok with my ethernet connection.
Am I missing something?
Other data:
MTU: 1500
L2 MTU: 1600
Band: 2Ghz only-N
WIFI: 2.4ghz
Channel Width: 20MHz
Frequeny: 2417 (Channel 2)
Wireles Protocol: 802.11
Encryption: WPA2 AES
Frequecy Mode: superchannel
Antenna Gain: 0
Tx Chains: Chain0 & Chain1 (I’ve tried every combination)
Rx Chains: Chain0 & Chain1(I’ve tried every combination)
Tx Power Mode: card rates
Tx Power: 17
On “Current TX Power” tab “rate” value goes from 1Mbps to 54Mbps.
Oh and the router is in IKEA PS Cabinet (http://www.ikea.com/gb/en/products/storage-furniture/cabinets-sideboards/ikea-ps-cabinet-white-art-10251451/). That’s why I need external antenna. I thought It would have solved my problem.
Try using the extension channel (40 Mhz), use wpa2-aes only for encryption and enable wmm.
If I understand correct, you’re using one antenna, that’s only one chain:
https://superuser.com/questions/744065/what-is-an-antenna-chain-and-how-do-i-figure-out-the-correct-setting-for-my-rout
I am already using WPA2-AES. I use 20MHz width because I’ve read some articles where It says 40MHz is not so good for 2.4MHz WIFI.
RB751 external antenna was not very good, it will not improve the situation. What is the signal right now, without the antenna?
Signal strength is normal, but speed is 4Mbps (out of 300Mbps). The problem is also that I am not sure which antenna is transmitting. Is there a way to disable all internal antennas?
please post specific signal info
for example, from the registration table entry on my device, which has excellent signal (same model as yours):
Last Activity		0.000 s
Tx/Rx Signal Strength		-46 dBm
Tx/Rx Signal Strength Ch0		-48 dBm
Tx/Rx Signal Strength Ch1		-53 dBm
Tx/Rx Signal Strength Ch2		-54 dBm
Signal To Noise		59 dB
Tx/Rx CCQ		100 %
P Throughput		30502 kbps
/interface wireless registration-table> print
 # INTERFACE                                                              RADIO-NAME       MAC-ADDRESS       AP  SIGNAL-STRENGTH TX-RATE UPTIME
 0 WLAN        no  -28dBm@1Mbps    11Mbps  1m15s
 1 WLAN        no  -67dBm@1Mbps    39Mb... 1m12s
/interface wireless registration-table> print oid
0 signal-strength=.1.3.6.1.4.1.14988.1.1.1.2.1.3.232.78.6.49.128.202.6 tx-signal-strength=.1.3.6.1.4.1.14988.1.1.1.2.1.19.232.78.6.49.128.202.6
tx-bytes=.1.3.6.1.4.1.14988.1.1.1.2.1.4.232.78.6.49.128.202.6 rx-bytes=.1.3.6.1.4.1.14988.1.1.1.2.1.5.232.78.6.49.128.202.6
tx-packets=.1.3.6.1.4.1.14988.1.1.1.2.1.6.232.78.6.49.128.202.6 rx-packets=.1.3.6.1.4.1.14988.1.1.1.2.1.7.232.78.6.49.128.202.6
tx-rate=.1.3.6.1.4.1.14988.1.1.1.2.1.8.232.78.6.49.128.202.6 rx-rate=.1.3.6.1.4.1.14988.1.1.1.2.1.9.232.78.6.49.128.202.6
routeros-version=.1.3.6.1.4.1.14988.1.1.1.2.1.10.232.78.6.49.128.202.6 uptime=.1.3.6.1.4.1.14988.1.1.1.2.1.11.232.78.6.49.128.202.6
signal-to-noise=.1.3.6.1.4.1.14988.1.1.1.2.1.12.232.78.6.49.128.202.6 tx-signal-strength-ch0=.1.3.6.1.4.1.14988.1.1.1.2.1.13.232.78.6.49.128.202.6
signal-strength-ch0=.1.3.6.1.4.1.14988.1.1.1.2.1.14.232.78.6.49.128.202.6 tx-signal-strength-ch1=.1.3.6.1.4.1.14988.1.1.1.2.1.15.232.78.6.49.128.202.6
signal-strength-ch1=.1.3.6.1.4.1.14988.1.1.1.2.1.16.232.78.6.49.128.202.6 tx-signal-strength-ch2=.1.3.6.1.4.1.14988.1.1.1.2.1.17.232.78.6.49.128.202.6
signal-strength-ch2=.1.3.6.1.4.1.14988.1.1.1.2.1.18.232.78.6.49.128.202.6
1 signal-strength=.1.3.6.1.4.1.14988.1.1.1.2.1.3.132.56.53.81.78.122.6 tx-signal-strength=.1.3.6.1.4.1.14988.1.1.1.2.1.19.132.56.53.81.78.122.6
tx-bytes=.1.3.6.1.4.1.14988.1.1.1.2.1.4.132.56.53.81.78.122.6 rx-bytes=.1.3.6.1.4.1.14988.1.1.1.2.1.5.132.56.53.81.78.122.6
tx-packets=.1.3.6.1.4.1.14988.1.1.1.2.1.6.132.56.53.81.78.122.6 rx-packets=.1.3.6.1.4.1.14988.1.1.1.2.1.7.132.56.53.81.78.122.6
tx-rate=.1.3.6.1.4.1.14988.1.1.1.2.1.8.132.56.53.81.78.122.6 rx-rate=.1.3.6.1.4.1.14988.1.1.1.2.1.9.132.56.53.81.78.122.6
routeros-version=.1.3.6.1.4.1.14988.1.1.1.2.1.10.132.56.53.81.78.122.6 uptime=.1.3.6.1.4.1.14988.1.1.1.2.1.11.132.56.53.81.78.122.6
signal-to-noise=.1.3.6.1.4.1.14988.1.1.1.2.1.12.132.56.53.81.78.122.6 tx-signal-strength-ch0=.1.3.6.1.4.1.14988.1.1.1.2.1.13.132.56.53.81.78.122.6
signal-strength-ch0=.1.3.6.1.4.1.14988.1.1.1.2.1.14.132.56.53.81.78.122.6 tx-signal-strength-ch1=.1.3.6.1.4.1.14988.1.1.1.2.1.15.132.56.53.81.78.122.6
signal-strength-ch1=.1.3.6.1.4.1.14988.1.1.1.2.1.16.132.56.53.81.78.122.6 tx-signal-strength-ch2=.1.3.6.1.4.1.14988.1.1.1.2.1.17.132.56.53.81.78.122.6
signal-strength-ch2=.1.3.6.1.4.1.14988.1.1.1.2.1.18.132.56.53.81.78.122.6
Still having the problem …
hello,
looks like client device is stuck at 802.11g rates. please send us supout.rif file to:
support@mikrotik.com
