New to routerOS.. still trying to figure it out. Just came from 3 years of DD-WRT.
Subject says it all really. If there is already a post discussing this, please link it.
To be more specific, I’ll explain the situation.
I run an older fCraft server [Minecraft Classic] for a buddy of mine over the internet, and have been for years. After swapping out routers[from DD-WRT to routerOS], this issue has seemed to arrive. Anyone who connects to the server, shows up with the same IP. At first, I had masquerade enabled but swapped it out in favor of src-nat. From what my server sees, this changed from my routers internal lan IP to my external IP provided by my ISP. [Progress?]
But now I’m stumped, not sure what is causing clients to arrive on the same address. Have done hours of searching to no luck. I want to say it’s a NAT issue but again, not sure where to go at this point.
Server in question is located at 10.0.0.122.
My public address given to the router is 108.196.242.6
Box: CRS125-24G-1S
CFW: 3.22
UFW: 3.22
WFG: 6.27
sup-output:
uptime: 4d17h5m41s
version: 6.27
build-time: Feb/11/2015 13:24:13
free-memory: 98.4MiB
total-memory: 128.0MiB
cpu: MIPS 74Kc V4.12
cpu-count: 1
cpu-frequency: 600MHz
cpu-load: 42%
free-hdd-space: 109.9MiB
total-hdd-space: 128.0MiB
write-sect-since-reboot: 14945
write-sect-total: 108056
bad-blocks: 0%
architecture-name: mipsbe
board-name: CRS125-24G-1S
platform: MikroTik
CLOCK
time: 05:01:23
date: may/14/2015
time-zone-autodetect: yes
time-zone-name: America/Chicago
gmt-offset: -05:00
dst-active: yes
IRQs
Flags: ro - read-only
# IRQ USERS CPU ACTIVE-CPU COUNT
0 3 usb1 auto 539
1 4 switch0 auto 72 167 908
2 16 beeper auto 1 602
3 19 serial auto 18
4 112 ts auto 0
SYSTEM
Linux mydnsname 3.3.5 #2 Wed Feb 11 08:33:33 EET 2015 mips unknown
0 3 usb1 auto 539
3 19 serial auto 18
4 112 ts auto 0
SYSTEM
MEMORY
MemTotal: 125424 kB
MemFree: 72112 kB
Buffers: 0 kB
Cached: 30776 kB
SwapCached: 0 kB
Active: 12476 kB
Inactive: 25844 kB
Active(anon): 8644 kB
Inactive(anon): 64 kB
Active(file): 3832 kB
Inactive(file): 25780 kB
Unevictable: 1264 kB
Mlocked: 1264 kB
SwapTotal: 0 kB
SwapFree: 0 kB
Dirty: 0 kB
Writeback: 0 kB
AnonPages: 8828 kB
Mapped: 8380 kB
Shmem: 144 kB
Slab: 9396 kB
SReclaimable: 2820 kB
SUnreclaim: 6576 kB
KernelStack: 568 kB
PageTables: 724 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 62712 kB
Committed_AS: 80268 kB
VmallocTotal: 261940 kB
VmallocUsed: 23052 kB
VmallocChunk: 228492 kB
CPU
system type : Mikrotik CRS125G
processor : 0
cpu model : MIPS 74Kc V4.12
cpu MHz : 600.000
BogoMIPS : 299.82
wait instruction : yes
microsecond timers : yes
tlb_entries : 32
extra interrupt vector : no
hardware watchpoint : yes, count: 4, address/irw mask: [0x0000, 0x0ff8, 0x0ff8, 0x0ff8]
ASEs implemented : mips16
shadow register sets : 1
kscratch registers : 0
core : 0
VCED exceptions : not available
VCEI exceptions : not available
firewall supout:
# may/14/2015 05:01:23 by RouterOS 6.27
# software id =
add name=WAN
set [ find default-name=ether1 ] name=ether1-wlan
set [ find default-name=ether2 ] name=ether2-wlan
set [ find default-name=ether5 ] master-port=ether4
set [ find default-name=ether6 ] master-port=ether4
set [ find default-name=ether7 ] master-port=ether4
set [ find default-name=ether8 ] master-port=ether4
set [ find default-name=ether9 ] master-port=ether4
set [ find default-name=ether10 ] master-port=ether4
set [ find default-name=ether11 ] master-port=ether4
set [ find default-name=ether12 ] master-port=ether4
set [ find default-name=ether13 ] master-port=ether4
set [ find default-name=ether14 ] master-port=ether4
set [ find default-name=ether15 ] master-port=ether4
set [ find default-name=ether16 ] master-port=ether4
set [ find default-name=ether17 ] master-port=ether4
set [ find default-name=ether18 ] master-port=ether4
set [ find default-name=ether19 ] master-port=ether4
set [ find default-name=ether20 ] master-port=ether4
set [ find default-name=ether21 ] master-port=ether4
set [ find default-name=ether22 ] master-port=ether4
set [ find default-name=ether23 ] master-port=ether4
set [ find default-name=ether24 ] master-port=ether4
set [ find default-name=sfp1 ] master-port=ether4
set [ find default-name=ether3 ] master-port=ether4
add name=dhcp ranges=10.0.0.10-10.0.0.254
add address-pool=dhcp disabled=no interface=ether4 lease-time=23h name=mdhcp
/ipv6 pool
add name=AT&THSTNTX prefix-length=63
/port
set 0 name=serial0
/queue simple
add disabled=yes name=bandwidth target=108.196.242.6/32
add bridge=WAN interface=ether1-wlan
add bridge=WAN interface=ether2-wlan
/ip settings
set accept-redirects=yes
add address=10.0.0.1/8 interface=ether4 network=10.0.0.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1-wlan
add add-default-route=no dhcp-options=hostname,clientid disabled=no \
/ip dhcp-server lease
add address=10.0.0.11 client-id=1:0:18:dd:31:cd:11 mac-address=\
00:18:DD:31:CD:11 server=mdhcp
add address=10.0.0.122 mac-address=D4:3D:7E:4B:AD:EC
add address=10.0.0.120 client-id=1:68:1c:a2:12:2d:f0 mac-address=\
68:1C:A2:12:2D:F0 server=mdhcp
add address=10.0.0.121 client-id=1:68:1c:a2:12:2d:ef mac-address=\
68:1C:A2:12:2D:EF server=mdhcp
add address=10.0.0.0/8 domain=mydnsname gateway=10.0.0.1 netmask=8
set allow-remote-requests=yes
add action=add-src-to-address-list address-list=ssh_blacklist \
address-list-timeout=1w3d chain=input comment="SSH Access blockade" \
connection-state=new disabled=yes dst-port=22 protocol=tcp \
src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3 \
address-list-timeout=1m chain=input connection-state=new disabled=yes \
dst-port=22 protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2 \
dst-port=22 protocol=tcp src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1 \
add action=src-nat chain=srcnat comment=MAINNAT-DD to-addresses=108.196.242.6
add action=dst-nat chain=dstnat comment="S2-RDP BLAKBAWX" dst-address=\
108.196.242.6 dst-port=10500 protocol=tcp to-addresses=10.0.0.122 \
to-ports=10500
add action=masquerade chain=srcnat comment=REVNAT-DD disabled=yes \
out-interface=ether4
add action=dst-nat chain=dstnat comment=S2-EMBY dst-address=108.196.242.6 \
dst-port=8920 protocol=tcp to-addresses=10.0.0.122 to-ports=8920
add action=dst-nat chain=dstnat dst-address=108.196.242.6 dst-port=8096 \
protocol=tcp to-addresses=10.0.0.122 to-ports=8096
add action=dst-nat chain=dstnat dst-address=108.196.242.6 dst-port=8866 \
protocol=tcp to-addresses=10.0.0.122 to-ports=8866
add action=dst-nat chain=dstnat dst-address=108.196.242.6 dst-port=37218 \
protocol=tcp to-addresses=10.0.0.122 to-ports=37218
add action=dst-nat chain=dstnat comment=MT-W.AP dst-address=108.196.242.6 \
dst-port=50041 protocol=tcp to-addresses=10.0.0.4 to-ports=80
add action=dst-nat chain=dstnat comment="S2-Minecraft Classic" dst-address=\
108.196.242.6 dst-port=25545 protocol=tcp to-addresses=10.0.0.122 \
to-ports=25545
add action=dst-nat chain=dstnat dst-address=108.196.242.6 dst-port=8042 \
protocol=tcp to-addresses=10.0.0.11 to-ports=80
add action=dst-nat chain=dstnat disabled=yes dst-port=25565 protocol=tcp \
to-addresses=10.0.0.122 to-ports=25565
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh port=
set api disabled=yes
set winbox disabled=yes
set api-ssl disabled=yes
/ip traffic-flow
set interfaces=ether1-wlan
/ip upnp
set enabled=yes
/ipv6 dhcp-client
add disabled=yes interface=ether1-wlan pool-name=AT&THSTNTX
add disabled=yes interface=ether2-wlan pool-name=AT&THSTNTX
/system clock
set time-zone-name=America/Chicago
/system clock manual
set time-zone=-06:00
/system identity
set name=mydnsname
/system ntp client
set enabled=yes primary-ntp=128.138.141.172
/tool graphing interface
add interface=ether1-wlan
Don’t really care my IP is out there, lol. I already get hundreds of failed brute force login attempts daily from all over the world on default ports. [Not the problem here, however]
If it needs to be removed though, please feel free to edit it or I can remove it.
If I need to give more info, let me know what y’all need. Thanks in advance for all your help.
