diskgenius: first partition 800GB, primary, ext4, second linux swap, 4GB, rest unassigned.
After connection and at any time on part2 "partitons overlaps with part1-part2" (or part1-par6)
lags: X - DISABLED; E - EMPTY, B - BLOCK-DEVICE; M - MOUNTED; g - GUID-PARTITION-TABLE, p - PARTITION; s - SMB-SHARING; m - MEDIA-SHARING
Columns: SLOT, MOUNT-POINT, MODEL, SERIAL, INTERFACE, SIZE, FREE, USE, FS
SLOT MOUNT-POINT MODEL SERIAL INTERFACE SIZE FREE USE FS
0 X file-usb1-part2-swapfile /usb1-part2/swapfile -
1 B gsm usb1 Realtek RTL9210B-CG 1342925150003 USB 3.20 5000Mbps 1 024 209 543 168 -
2 BMpsm usb1-part1 usb1-part1 Realtek RTL9210B-CG @1'048'576-858'993'459'200 858 992 410 624 805 215 567 872 0% ext4
3B psm usb1-part2 Realtek RTL9210B-CG @858'993'459'200-863'288'426'496 4,294,967,296 -
4 E p usb1-part3 -
5 E psm usb1-part6
it's the same when I create partitions via minitool
