Does anyone know if it is possible to use the serial port within RouterOS for generating alarms? We currently Use some high grade linux based cameras which have a serial interface for connecting open relay device such as door entry systems. I know there are devices out there that can easily do this but can’t see any technical reason why it couldn’t be done within the CPE as long as the software supported it.
Anybody with information on how to do this, it would have many applications.
Thanks and regards,
Justin
Answered my own question, RTFM! ![]()
Disable the console with
system console set 0 disabled=yes
then start talking to it with
serial-terminal serial0
Cheers,
JC
