I just installed a router, and i have some problems accesing a server from outside, in lan everything works.
I have a basic fw configuration, and when i disable the last drop rule everything works.
How can i ask this question properly? What information is needed?
If i log the output it says
forward in waninterface out:localbridge src-mac xxxx proto TCP (SYN) ext ip → internal ip:port
Please i need some advice, thanks in advance
