External IP with Public IP assignment
Dear MK Enthusiasts,
I need your help, I’m a little confused with a scenario.
I’ve got a CCR connected to my provider with private interconnection IP ( /30 ). My provider route a /27 to this ip.
I want to deliver /27 to my customers with few service ( queue / basic FW )
I add last IP of my /27 on an interface, and give public IP to my customers, my interface become their GW.
I’m a little confused with NAT translation ( masquerade ), my customers with public IP don’t see their own external public IP, but mine.
0    chain=srcnat action=masquerade out-interface=sfp1 - INTERCO log=no log-prefix=""
1    chain=srcnat action=masquerade out-interface=sfp5 - CUSTOMER PUBLIC NET log=no log-prefix=""
Can you please advice me to resolve this situation ?
Armel
Why are you doing NAT if you are working with public IPs?
disable those masquerade rules, that’s all needed.
you may need to remove all connectionsin ip > Firewall > Connections or reboot after that.
Even if my interconnexion IP is in a private range ?
I’ve got a management network ( private ).
Does I need to put a masquerade rule with address list ( lan ) ?
Thanks a lot
Armel
I’d need an schematic and actual export prior to assess that.
Sorry for my late reply :
Here is my conf :
/ip address print
ADDRESS            	NETWORK         	INTERFACE
37.x.x.185/29  		37.x.x.184  		ether3_PUBLIC
172.19.0.37/30    	172.19.0.36     	ether2_INTERCO
/ip route print
DST-ADDRESS       	 PREF-SRC        	GATEWAY            	DISTANCE
0.0.0.0/0                          172.19.0.38            		 			1
37.x.x.184/29  			37.x.x.185 	 	ether3_PUBLIC          255
172.19.0.36/30     		172.19.0.37    		ether2_INTERCO    0
I can ping server from outside, but can’t ping from server to outside ( IP or DNS ). No FW rules, no NAT rules.
If I make NAT ( masquerade ), all is working fine, but when I look about my external IP, it’s the nated one, not the real of the server.
Thanks for your help
A.
Are you saying that with NAT disabled, if you browse whatismiip from a host with a public IP, the ip displayed is 37.x.x.185?
What gateway has the server set as default?
Yes, thanks, off course.
WITHOUT MASQUERADING, I can ping server from outside, but can’t ping from my server to outside, no websurfing or any service. Very strange. No FW rule or any extra NAT rules.
Armel
can you please post the server routing table?
Nothing specific.
For now, it’s a laptop with public ip…
I can ping it from outside, but laptop can’t ping anything… I’ve rebooted router, clear my session table.
I’m a bit lost :slight_smile:
Armel
Yours is a routing problem, without more details I cannot point you in the right direction.
a “route print” plus a “ipconfig /all” on a cmd if it’s a windows laptop will make things easier.
