external to internal connection for ssh
How to avoid booking cannot be off by ssh port on mikrotik routers
can’t remember anymore
and another question, how can I identify the local dhcp server to the network. interfere with the other. The only network mikrotik router would it?
Whether it’s a DHCP relay?
To prevent DHCP servers to be interogated, you have to filter ports UDP/67 and UDP/68 from other network segments.
The SSH part: try to reformulate your question since it is not clear what you need.
