External To Internal
Hello
i have a Public IP like : 203.188.2–.— and it’s set on Router.
now i want to fw it to a internal web server.
i use dst-nat 203.188.2–.— on port 80 to internal dst-nat 192.168.202.2 on port 80. it dosent work .
but if i use dst-nat 203.188.2–.— on port 80 to internal dst-nat 74.125.67.100 (google IP ) on port 80 it works.
so what’s the problem with my internal ip ?
thanks
you need to set up a simple DST-NAT rule that will take care of the redirection. For example:
/ip firewall nat add chain=dstnat dst-address=10.5.8.200 action=dst-nat to-addresses=192.168.0.109
(you can also specify certain ports)
thanks but it can redirect another ip like google. yahoo but it not redirect in my intrnal ip.
i add this
/ip firewall nat add chain=dstnat dst-address=203.188.242.114 action=dst-nat to-addresses=192.168.202.2
but it can’t redirect to 192.168.202.2 it say page not found.
but if i use /ip firewall nat add chain=dstnat dst-address=203.188.242.114 action=dst-nat to-addresses=74.125.67.100 it works
what’s the problem ?
pls help me
Are you testing from same subnet 192.168.202.0/24? If yes you should add another nat rule for internal traffic!
Problem Solved . by adding this
/ip firewall nat add chain=srcnat dst-address=192.168.0.109 action=src-nat to-addresses=10.5.8.200
