extra channel upgrade problem
Hi
Ive installed the extra channel upgrade, but now when trying to link the sites using any of the additional frequencies the radios wont connect. As soon as i use any of the default channels they link up perfectly .
What could be the problem.
Regards
Shaun
have you change the Frequency Mode to be “superchannel”?
client end needs to add the AP frequency also in the “scan list” setting, so that he knows where to look for it
normis…
any topic talk about how to use the alignment mode?
Thanks guys, adding to scan list was the answer i needed :slight_smile: Have a great week :slight_smile:
