is it possible to extract the config from an unexcrypted backup file? Problem is that I can’t connect to a maplite via ethernet (configured as WAN) but only via WiFi and forgot the WiFi password. I made a backup but did not export an rsc file.
Well, the eth interface is configured as WAN in this configuration and does not accept ssh/winbox/http(s) connections nor L2 connections (Mac-Telnet etc.).
Now you know the importance to not close MAC services on WAN side…
Simply open the backup with “notepad”
Is a mess, but the wifi password is on plaintext…
Just search wirelessprofile and the password is written a little further on in clear text
