Extreme HIGH Pings and LOSS when using Port Mirroring
Hey Guys,
here is the Problem when using Port Mirroring (Ingress and Egress) from Port 1 to Port 5.
Only 6-7mbit are going through. Ist that too much for SwOS and its 50mhz?
When i turn Port Mirroring OFF then everything is ok.
Zeitüberschreitung der Anforderung.
Antwort von 192.168.1.1: Bytes=32 Zeit=160ms TTL=63
Antwort von 192.168.1.1: Bytes=32 Zeit=248ms TTL=63
Antwort von 192.168.1.1: Bytes=32 Zeit=449ms TTL=63
Antwort von 192.168.1.1: Bytes=32 Zeit=214ms TTL=63
Antwort von 192.168.1.1: Bytes=32 Zeit=127ms TTL=63
Antwort von 192.168.1.1: Bytes=32 Zeit=132ms TTL=63
Thanks a lot
