Extremely weird issue with LtAP LTE6 Kit (2023)
UPDATE:
I have replaced one of the modems inside with an R11e-LTE6 I stashed somewhere and it immediately started working properly. I hope anyone that buys FG621-EA to make sure they work with their carrier before getting one.
I have an LtAP LTE6 running dual FG621-EA modems. LTE is connected and I am getting an IP address + a default from the carrier. However, I am not able to ping anything. There is absolutely no internet connectivity at all. This is happening on both modems. The same SIM card works fine in a phone as well as in an older LtAP LTE6 kit that has two R11e-LTE6 modems. Something is very wrong with these new modems. Does anyone have a clue what could be going on or any fixes? Because this has put a pause on my plans completely.
[admin@MikroTik] > /interface/lte/monitor lte2 once without-paging
            status: connected
             model: FG621-EA
          revision: 16121.1034.00.01.01.04
  current-operator: Operator
    current-cellid: 221697
            enb-id: 866
         sector-id: 1
        phy-cellid: 99
        data-class: LTE
    session-uptime: 4m34s
              imei: 8888888888888888
              imsi: 8888888888888888
              uicc: 88888888888888888888
      primary-band: B3@20Mhz earfcn: 1500 phy-cellid: 99
           ca-band: B3@20Mhz earfcn: 1302 phy-cellid: 99
                ri: 2
              rssi: -49dBm
              rsrp: -71dBm
              rsrq: -7dB
              sinr: 15dB
[admin@MikroTik] > /ip/address print
Flags: D - DYNAMIC
Columns: ADDRESS, NETWORK, INTERFACE
#   ADDRESS           NETWORK        INTERFACE
0 D 10.151.144.57/32  10.151.144.57  lte2
[admin@MikroTik] > /ip/route print
Flags: D - DYNAMIC; A - ACTIVE; c - CONNECT, m - MODEM
Columns: DST-ADDRESS, GATEWAY, DISTANCE
    DST-ADDRESS       GATEWAY  DISTANCE
DAm 0.0.0.0/0         lte2            2
DAc 10.151.144.57/32  lte2            0
[admin@MikroTik] > ping 1.1.1.1
  SEQ HOST                                     SIZE TTL TIME       STATUS
    0 1.1.1.1                                                      timeout
    1 1.1.1.1                                                      timeout
    2 1.1.1.1                                                      timeout
    3 1.1.1.1                                                      timeout
    sent=4 received=0 packet-loss=100%
