is this correct???
only seeing 22dbm when should be 28dbm…
routerboard 800 with ros 5.11
Hello ![]()
I’m not sure with F50N, but i suppose its the same like F52N.
If you look at the data-sheet you will see that it has 5dB offset.
This means that when you set your radio card to transmit with 20dB, the real power is 25dB.
Hope this helps,
Yes, you are right..
If it’s the F50-Pro, the tx power offset is 7dbm…
