Facebook Full Speed script
hello to every one…!!!
i am searching about facebook full speed script. script bypass the user speed limit profile and browse user only facebook unlimited speed. i am also used walled grande but this option is allow to user browse with out login use wtih full speed :frowning:
Make a mangle of facebook connection and then mark packets. Create queue to catch this packets.
Sent from my iPhone using Tapatalk
OS v6 only
/ip firewall layer7-protocol
add name=swf regexp=.swf
add name=videoplayback regexp=videoplayback
/ip firewall mangle
add action=mark-connection chain=prerouting comment=“\CA\D5\DD\CD \C7\E1\E3\E6
\C7\DE\DA \E3\ED\DF\D1\E6\CA\ED\DF \C7\E1\DA\D1\C8” disabled=no
layer7-protocol=jpg new-connection-mark=Browsing passthrough=yes
add action=mark-connection chain=prerouting disabled=no layer7-protocol=gif
add action=mark-connection chain=prerouting disabled=no layer7-protocol=png
add action=mark-packet chain=postrouting connection-mark=Browsing disabled=no
new-packet-mark=Browsing passthrough=no
add action=mark-connection chain=prerouting comment=“\C7\E1\DA\C7\C8 \C7\E1\DD
\ED\D3 \E6\C7\E6\E4\E1\C7\ED\E4 \E3\ED\DF\D1\E6\CA\ED\DF \C7\E1\DA\D1\C8”
disabled=no layer7-protocol=swf new-connection-mark=swf passthrough=yes
add action=mark-packet chain=postrouting connection-mark=swf disabled=no
new-packet-mark=swf passthrough=no
“\C7\E1\ED\E6\CA\ED\E6\C8 \E3\ED\DF\D1\E6\CA\ED\DF \C7\E1\DA\D1\C8”
disabled=no layer7-protocol=videoplayback new-connection-mark=
videoplayback passthrough=yes
add action=mark-packet chain=postrouting connection-mark=videoplayback
disabled=no new-packet-mark=videoplayback passthrough=no
/queue type
add kind=pcq name=300k pcq-burst-rate=0 pcq-burst-threshold=0 pcq-burst-time=
10s pcq-classifier=dst-address pcq-dst-address-mask=32
pcq-dst-address6-mask=64 pcq-limit=50 pcq-rate=300k pcq-src-address-mask=32
pcq-src-address6-mask=64 pcq-total-limit=2000
add kind=pcq name=512k pcq-burst-rate=0 pcq-burst-threshold=0 pcq-burst-time=
pcq-dst-address6-mask=64 pcq-limit=50 pcq-rate=512k pcq-src-address-mask=32
add kind=pcq name=700k pcq-burst-rate=0 pcq-burst-threshold=0 pcq-burst-time=
pcq-dst-address6-mask=64 pcq-limit=50 pcq-rate=700k pcq-src-address-mask=32
add kind=pcq name=1M pcq-burst-rate=0 pcq-burst-threshold=0 pcq-burst-time=10s
pcq-classifier=dst-address pcq-dst-address-mask=32 pcq-dst-address6-mask=64
pcq-limit=50 pcq-rate=800k pcq-src-address-mask=32 pcq-src-address6-mask=64
add kind=pcq name=2M pcq-burst-rate=0 pcq-burst-threshold=0 pcq-burst-time=10s
pcq-limit=50 pcq-rate=2M pcq-src-address-mask=32 pcq-src-address6-mask=64
add kind=pcq name=3M pcq-burst-rate=0 pcq-burst-threshold=0 pcq-burst-time=10s
pcq-limit=50 pcq-rate=3M pcq-src-address-mask=32 pcq-src-address6-mask=64
add kind=pcq name=4M pcq-burst-rate=0 pcq-burst-threshold=0 pcq-burst-time=10s
pcq-limit=50 pcq-rate=4M pcq-src-address-mask=32 pcq-src-address6-mask=64
add kind=pcq name=“Full Speed” pcq-burst-rate=0 pcq-burst-threshold=0
pcq-burst-time=10s pcq-classifier=dst-address pcq-dst-address-mask=32
pcq-dst-address6-mask=64 pcq-limit=50 pcq-rate=0 pcq-src-address-mask=32
/queue tree
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0
max-limit=0 name=Browsing packet-mark=Browsing parent=global-out priority=1
queue=“Full Speed”
max-limit=0 name=videoplayback packet-mark=videoplayback parent=global-out
priority=8 queue=1M
max-limit=0 name=swf packet-mark=swf parent=global-out priority=8 queue=1M
do you use this script on ppoe server for pppoe connections ?
yes but its causing peak problems as i dont have enough bandwidth. if someone can help in editing it for me i am really grateful
http://forum.mikrotik.com/t/editing-help-needed/103882/1
todayheads
This script working fine only hotspot..? Can you use this script at this time. If you say yes then I try this code. mostly user use only facebook in my network
I only want facebook full speed script not to all websites picture and videos. Script just like a bypass a website. Bypass website Browe(use) full bandwidth of network
well i am sorry i cant help u further
just ask someone to edit the script i gave you to suit ur needs
Is this script for Facebook Fast
