HELLO,
I’m writing to see if you can help me. I am trying to create and configure the social login of facebook, so that the user connects to the wifi and likes to work. Well, it worked a while ago, but it stopped working and we do not know why.
I put an image on the pc works correct but mobile device does not
Now that is really little information you provided ![]()
If it used to work and suddenly doesn’t, something must have changed.
Did you recently add PCC load balancing?
Did you change addresses?
Did you upgrade firmware?
and so on…
-Chris
