Hello Mikrotik,
i have a mikrotik rb333.I am faceing proublem to access mikrotik from using public ip address in google chrome,firefox,ucbrowser etc.I am able to access this from any where by using the mikrotik app and winbox but unable to access from browsers and when i fill up my ip in browser and tap enter this show some firepro router please help me friends.i attach a screenshot of the proublem i face.
FirePro RouterOS Managing Webpage.pdf (72 KB)
Congratulations, you have revealed the public address of the machine as the links in the pdf contain it ![]()
Other than that, use Winbox to check the /ip firewall settings and the /ip service settings. It seems that the firepro customization redirects the web access to the machine to a hotspot welcome page showing you what you’ve posted. Leaving http access to management interfaces open to the internet is definitely a bad idea, you should configure https and disable http as a minimum.
sir,
i give access of teamviewer,anydesk and mikrotik to you.Can you help me please?
I’m not sure it is the best way to go. First, what is the desired resulting configuration? Why is connection from internet using Winbox not sufficient for your needs?
Dear Sir,
when i am outoff station without laptop than i am unable to access router from my phone this is the proublem.8607242412 is my contact or whatsapp number if you know any solution then please help me sir.
thank you for giving your valuable time.
When you are connected to the LAN side of the router, can you connect using Webfig on http (port 80) or not? If yes, would a solution with http access via a L2TP/IPsec VPN (which both Android and iOS phones support natively) be OK for you?
While logged in using Winbox, can you press the Terminal button and then follow the instructions in my automated signature?
Dear Sir,
please give me instructions.
i press the terminal option,now?
Yes. You press the “Terminal” button, write /export hide-sensitive in the window which opens, copy the output to a text editor and do what is written in my signature here. Then, you paste the result here.
[admin@Kaluwas Office] > /export hide-sensitive
jul/09/2018 20:48:50 by RouterOS 6.42.5
software id = MBJC-DWSD
model = 333
serial number = 179801C21Q9A
set [ find default-name=ether2 ] name=Lan2
set [ find default-name=ether1 ] name=WAN
set [ find default-name=ether3 ] disabled=yes
set [ find default=yes ] group-ciphers="" supplicant-identity=Firepro
unicast-ciphers=""
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
/port
set 0 flow-control=hardware
/queue simple
add max-limit=60M/60M name=home target=172.10.10.2/32
add max-limit=3M/5M name=mukesh target=172.10.10.3/32
add max-limit=5M/5M name=ashish target=172.10.10.4/32
add max-limit=2M/2M name=kuldeep target=172.10.10.6/32
add max-limit=1M/1M name=vikas target=172.10.10.7/32
add disabled=yes max-limit=1M/1M name=ombir target=172.10.10.8/32
add disabled=yes max-limit=2M/15M name=sunil target=172.10.10.9/32
add max-limit=5M/5M name=bintu target=172.10.10.10/32
/queue interface
set Lan2 queue=ethernet-default
set WAN queue=ethernet-default
set ether3 queue=ethernet-default
/system logging action
set 0 memory-lines=100
set 1 disk-lines-per-file=100
add address=111.223.3.61/26 interface=WAN network=111.223.3.0
add address=172.10.10.1/24 interface=Lan2 network=172.10.10.0
set allow-remote-requests=yes max-udp-packet-size=512 servers=1.1.1.1,8.8.8.8
add distance=1 gateway=111.223.3.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Asia/Kolkata
/system identity
set name="Kaluwas Office"
/system routerboard settings
set cpu-frequency=266MHz silent-boot=no
/tool graphing interface
add
/tool graphing queue
add allow-address=172.10.10.2/32 simple-queue=mukesh
add allow-address=172.10.10.3/32 simple-queue=ashish
Assuming that you have posted the complete configuration, it seems that Firepro’s customization of RouterOS went further than I’ve expected (remember that I’m not associated to Mikrotikls SA in any way, I’m just a user like you). The http service is not disabled in /ip service, nor there is any redirection in the /ip firewall nat which would explain why access from public IP addresses is opening that informative page rather than the normal Webfig one, nor there is any /ip hotspot configuration which would explain that redirection. So I repeat my question - if you connect, using your browser, from the private network (via ether2), do you get the same page like the one you get via ether1 or you get a normal WebFig?
Another possibility could be that RB333 is so old that it doesn’t support WebFig at all, so it’s not a matter of Firepro’s customization but Mikrotik’s standard solution for PPC devices. No idea, honestly.
What bothers me most of all is that your firewall is nonexistent so you solely rely on impenetrability of the http server which is a really bad idea.
But there is a strange thing:
add
The empty add line suggests some copy-paste issues. Can you do /export hide-sensitive file=cfg-export, then download the file cfg-export.rsc and post it?
how i remove customization?
From where have you downloaded the 6.42.5, from Firepro’s pages or from Mikrotik’s? Or you’ve just used the auto-upgrade?
Nope. RB333 is old, but still usable and has all standard RouterOS features, WebFig included.
I don’t know if it’s this, but some semi-secret “branding maker” (or similar name) exists, which allows to create customization package. I don’t know what all features it has, I’ve never seen it, because it’s not publicly available. But I’ve seen few routers with changed logos and such, so I guess it might be it. It’s relatively persistent, it survives config reset. But netinstall was able to deal with it.
Just add “/webfig” to the url and you’ll get the WebFig login.
In retrospect, it’s pretty obvious thing to try, isn’t it? ![]()
Sure… I’m however seriously afraid we have another easy target here, as the OP seems to be concentrated on ability to access the device remotely and ignores the risks ![]()
