Hi
Can someone of you see what i am doning wrong?
I was able to ping from 10.0.0.1 to 192.168.88.1 and reverse.
I was able to access 10.0.0.1 from 192.168.88.1
now it stoped suddenly… something i have wrong i can see Connections in Firewall but they dont connect:
results of my logging:
10.0.0.1: GW i try to ping, 10.0.0.66:80 is a website i try to open with my browser.
SRCNAT srcnat: in:bridge out:ether1, connection-state:new src-mac 00:25:22:db:94:83, proto ICMP (type 8, code 0), 192.168.88.249->10.0.0.1, len 60
SRCNAT srcnat: in:bridge out:ether1, connection-state:new src-mac a6:c9:7f:0a:e5:07, proto TCP (SYN), 192.168.88.252:58639->10.0.0.66:80, len 64
compact file show-sensitive terse verbose
[mark@ixofficeac2] > export
# feb/26/2023 13:09:34 by RouterOS 7.7
# software id = 5G9Y-BARC
# model = RBD52G-5HacD2HnD
# serial number = XXXXXXXX
add admin-mac=C4:AD:34:BD:D6:45 auto-mac=no comment=defconf fast-forward=no \
name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
country=austria disabled=no distance=indoors frequency=auto installation=\
indoor mode=ap-bridge ssid=XXXXXX station-roaming=enabled \
wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX \
indoor mode=ap-bridge ssid=XXXXXXX station-roaming=enabled \
/interface wireguard
add disabled=yes listen-port=51820 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] ip-type=ipv4
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
dynamic-keys supplicant-identity=MikroTik
/ip ipsec peer
add address=92.61XXXX/32 exchange-mode=ike2 local-address=92.61.XXXXX name=\
cottagemonster
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048 enc-algorithm=aes-256 \
hash-algorithm=sha256 lifetime=8h proposal-check=strict
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256 enc-algorithms=aes-256-cbc \
lifetime=1h pfs-group=modp2048
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
/port
set 0 name=serial0
/snmp community
set [ find default=yes ] addresses=XXXXXX
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan2
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
192.168.88.0
add address=92.XXXX/28 interface=ether1 network=92.61XXXXXX
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
/ip dhcp-server lease
add address=192.168.88.250 client-id=1:0:11:32:47:5f:10 mac-address=\
00:11:32:47:5F:10 server=defconf
set allow-remote-requests=yes servers=208.67.222.222,208.67.220.220
/ip dns static
established,related,untracked
add action=accept chain=input src-address=XXXXXX
add action=accept chain=forward disabled=yes src-address=10.0.0.0/24
add action=accept chain=forward disabled=yes src-address=192.168.88.0/24
add action=accept chain=forward disabled=yes src-address=192.168.2.0/24
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=srcnat dst-address=10.0.0.0/24 log=yes log-prefix=\
SRCNAT src-address=192.168.88.0/24
add action=accept chain=srcnat disabled=yes dst-address=192.168.2.0/24 \
add action=accept chain=dstnat dst-address=192.168.88.0/24 log=yes log-prefix=\
DSTNAT src-address=10.0.0.0/24
add action=accept chain=dstnat disabled=yes dst-address=192.168.88.0/24 \
ipsec-policy=in,ipsec src-address=192.168.2.0/24
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
/ip ipsec identity
add peer=cottagemonster
/ip ipsec policy
add dst-address=10.0.0.0/24 peer=cottagemonster src-address=192.168.88.0/24 \
tunnel=yes
add dst-address=192.168.2.0/24 peer=cottagemonster src-address=192.168.88.0/24 \
tunnel=yes
add dst-address=0.0.0.0/0 gateway=PUPLICIPGW
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox address=\
REMOVED
set api-ssl disabled=yes
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=!LAN
invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
dst-address-list=bad_ipv6
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 \
protocol=udp
ipsec-ah
ipsec-esp
/system clock
set time-zone-name=Europe/Vienna
/system identity
set name=ixofficeac2
/system routerboard settings
set auto-upgrade=yes
/tool mac-server
/tool mac-server mac-winbox
Br
Mark
