Hallo
I have trouble to conect to the router after a factory reset .
I do the factory reste under system .and I uncheck the no default configuration .-
the winbox can se the router and I m note able to connect to it with mac .
what s the best why to do th efactory reset
Don’t use ether1 to connect.
you must use eth3 for connecting to the router , but if you tell me about your routerboard model number i can help you for resetting the routerboard
Best Regards,
ether3 ???
You can use all the ether interfaces exept ether1 if the routerboard is set to default
my router is rb 750. but i think it s general i have the same problem with rb1100 and the ccr router
Use ether 2 to 5 and try connect with winbox
Disable the firewall on your pc or laptop.
