the set up is that I have 2 static IP from my ISP, i just want it to load balance and a fail over.
have done all the example on the wiki but cant make it work! can ping and can browse with wan1 & wan 2 but when i remove wan1 it cannot browse anymore still can ping.
lots of people here are addicted in mikrotik in this room but without your network detail information no one can do magic for you, now post your configuration export it. maybe someone will do a trick for you
