Fail to display "reset counter" option with long l
Hi All,
This may be a bug - If you list the users in usermanager web console and display a list where the browser will scroll (say list 100 or more in the displayed user list) the “reset counters” floating option is clipped off the bottom of the screen when you scroll to the bottom. FF2, IE6, IE7 are all affected.
Therefore we have to reset in page after page whereas before we could list 1000, tick all, then click the “reset counters option”
Can we fix it?
Yes, thank you for the report, we are aware of the issue. We are planning to redesign current structure.
You can use workaround to resolve the problem for now, the table is on the bottom and new menu apperas after the table, menu is not visible, the solution is to move table lower.
It is possible in the different ways,
  1. click on user to opend detailed logs, move menu lower than the table;
  2. click on uise and ‘generate>voucher’ and move in the same manner.
we are working on a new design where this will be fixed. right now you can resize the window to reach the bottom of the menu. simply move one of the floating windows to the bottom of the page and you will get a scrollbar.
