Failed hotspot login showing 404 error
Hi everyone, I’m really new to mikrotik and I’ve been trying to figure out why when I enter wrong credentials on hotspot login I get an Error 404: Not Found message.
I want to display a message to the user saying incorrect credentials. I’ve already cheked https://wiki.mikrotik.com/wiki/Manual:Customizing_Hotspot and found that I had to create flogin.html. I did it, but that html file is not displayed when wrong credentials are entered. I just get the 404 error.
My questions are:
  1. Which html file MikroTik is trying to display? I thought it was flogin.html but it seems it is not.
  2. Which is the regular behaviour you get when wrong credentials are introduced?
  3. Is the 404 error saying that the user was not found or it means a given html file was not found in the mikrotik side? So far, I believe a html file is not found.
During the testing I’ve made, I’ve seen flogin displayed a couple of times only, but not in a regular way.
I have 7.1.1 routerOS, rb750gr3 and hotspot htmls are in factory version.
Thanks in advance.
+1
Please @mikrotik resolve
I need the fix too.
Same problem here, even on last “stable” 7.1.3… Any fix for this ???
Thanks in advanced
Try 7.2rc4. There was a fix for hotspot in there.
Guys there is a modification, now you can access userman directly in your winbox. Left panel options.
