I would like to ask you for help, I already spend 2 days googling and trying to solve myself.
I have reseted the router (Home AP Lite), configured it with quick configure to “Home AP”. Now I have perfectly working wifi but devices on ethernet cannot even ping the gateway. Linux refuses to connect. Windows 10 connects (saying no internet) it gets IP from DHCP (the same address is on device and in leases on the router + I have seen DHCP ack in wireshark) but it canot even ping the gateway. Windows diagnostics says gateway not available.
- I have tried all ethernet ports.
I have already tried turning off all blocking rule in firewall, and all rule in firewall.
I beliveve that NAT and masquerade are correct.
I tried this: http://forum.mikrotik.com/t/no-internet-over-lan-but-wlan-internet-is-ok/104602/1 (the ultimate solution) (attempt, not present in bellow config). I have tried to add relay for bridge and ether-2 (the one i am trying) to my providers DNS.
I strongly suspect subnet ranges to separate wlan1 and other ethers. But I found nothing.
Here is my dump of “expor hide-sensitive”:
# sep/01/2020 16:38:01 by RouterOS 6.47.2
# software id = UPHK-RN73
# model = RouterBOARD 941-2nD
# serial number = 80A7070FDFDC
add admin-mac=64:D1:54:F6:FB:6A auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n country="czech republic" disabled=no mode=ap-bridge ssid=dupakovi wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf hw=no interface=ether3
add bridge=bridge comment=defconf interface=pwr-line1
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
add address=10.9.68.254/30 interface=ether1 network=10.9.68.252
/ip dhcp-client
set allow-remote-requests=yes servers=10.255.255.10,10.255.255.20
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add distance=1 gateway=10.9.68.253
/system clock
set time-zone-name=Europe/Prague
/tool mac-server
/tool mac-server mac-winbox
Thanks for any suggestions.
