Failed to connect to OpenVPN from iOS
https://forums.openvpn.net/topic15760.html
I have same problem (ros 6.14, iOS 7.1.1). Guys on OpenVPN forum think it is a iOS app problem but I think is maybe something MT guys should check because absolutely same configuration with CentOS instead of Mikrotik works fine. Any ideas?
Note: Tried same config from Mac and PC. Works fine both with Mikrotik and CentOS.
If your problem are related to OpenVPN and UDP use:
RouterOS actually do not support OpenVPN link by UDP.
I don’t know what to say except that you missed the point. Read again :slight_smile:
:confused:
Have anybody an example of a full openvpn configuration?
Include the firewall settings?
