kvm make-routeros-image file-name=nfc2j file-size=256
failed to copy files to image
when i try to make a routeros-image. what could be the problem? do i need a VT-x CPU just for make the image?(not running the KVM yet, it’s my first time) i currently running on Pentium 4 CPU.
if VT-x CPU is positively the solution for this, i will get a dual-core CPU and motherboard tomorrow for the routeros. but i need to know it is exactly what i needed.
i know there is an old similiar thread for this problem, but there’s no solution there for me as they’re talking about older routeros version(v3.xx).
i bought a new CPU motherboard and RAM today, i’m gonna use them for mikrotik tomorrow morning. i’ll give you the result. beside, i tested v5.8 ROS in 24 hours trial mode, on the new CPU, it works anyway, the image is successfully created. i hope it will work on my main router hdd.
ok, tested it. it works at first boot. then few minutes later, i deleted the image and trying to remake it, but failed with the same error message. so i can draw conclusion, it wasn’t vt-x requirement at this stage.
either there is bad sector on my HDD, it is 4 years old already, or there’s bug, which blocking me from copying the the system files to the image. i will do check drive tomorrow morning.
it’s not demo license, but full 24hr trial license(equivalent to lvl 6 license).
beside i’m talking about my 4(probably 5)years old main ROS hdd. it has level 4 license.
i tested on both drives. the one that works at first boot, and not working later, is the old harddrive.
i didn’t run the vm yet though, it is just on the making-routeros-image process
it is related to my new PC i bought for this virtualization the old motherboard, had 4 PCI ports. the new one only 2. but it has onboard gigabit LAN. the problem is, it is unrecognized by ROS. so at the moment, i’m lack of port for my router. help please, thank you
