Failed to give out ip address
hi,
i have configure hotspot on CCR and i have found the following issue on the logs.
  1. dhcp error : dhcp 5: failed to give out ip address:pool is empty
  2. hotspot error info : failed to get ip address for hos 00:27:22:3B:2D:1A /105.53.137 pool empty
Any one have idea about this.
Hi, please paste the output of
/ip pool print
/ ip pool print
0 hs-pool-7 10.5.57.20-10.5.57.254
1 hs-pool-8 10.5.58.20-10.5.58.254
2 hs-pool-14 10.5.50.2-10.5.50.254
3 hs-pool-9 10.5.54.20-10.5.54.254
4 hs-pool-10 10.5.53.20-10.5.53.254
5 hs-pool-11 10.5.56.20-10.5.56.254
6 hs-pool-12 10.5.55.20-10.5.55.254
7 dhcp for office 192.168.1.2-192.168.1.200
Hi, It looks ok. How many hotspot client you have? Please check
/ip pool used print
Is there all ip used?
No all ip are not used.
Hi Kazim, All looks ok. Sorry i have no idea why not working. Which ROS version you are using? May be version upgrade can help you.
