failed to setup vm
Hi, im trying to add a vm using XEN, on routerOS 3.24 on amd sempron cpu with 512mb ram pc.
i tried 3.22 and upgraded to 3.24, still getting failed to setup vm error.
is that a bug,or the problem is anything else ?
It’s a bug. You should be setting the main memory down to leave some open for Xen to give to other VM’s, but that setting does not get obeyed in versions 3.23 or 3.24. Wait till 3.25 to see if it’s fixed.
thanks for reply.
yeah i noticed it, i set the main memory to 256mb but it is being ignored.
This still exists in v4.2
